Shek5150
Jul 15, 2023Aspirant
I'm needing to extend the reach of my Nighthawk AXE7800 Router
Greetings, I have a Rachio Wifi irrigation controller that is just outside the range of my Nighthawk AXE780 Router. So, I'm hoping that someone can recommend an extender that would be compa...
- Jul 15, 2023
The EAX80 would be closest and recommended. NG doesn't have a extender with 6Ghz as of yet. But the EAX80 should work well.
Jul 15, 2023Guru - Experienced User
Are you referring to the RAXE300 model router?
- Shek5150Jul 15, 2023Aspirant
Thanks for the reply.
I am referring to the RAXE300, apologies.
- FURRYe38Jul 15, 2023Guru - Experienced User
Very cool thanks for your help.
Out of curiosity, do you foresee a time when NG will come out with a fully copyable extender? . . not a big deal if this item will work . .. just curious.
Anyway, my irrigation system thanks you.
