Shek5150
Jul 15, 2023Aspirant
I'm needing to extend the reach of my Nighthawk AXE7800 Router
Greetings, I have a Rachio Wifi irrigation controller that is just outside the range of my Nighthawk AXE780 Router. So, I'm hoping that someone can recommend an extender that would be compa...
- Jul 15, 2023
The EAX80 would be closest and recommended. NG doesn't have a extender with 6Ghz as of yet. But the EAX80 should work well.
Jul 15, 2023Guru - Experienced User
Are you referring to the RAXE300 model router?
Shek5150
Thanks for the reply.
I am referring to the RAXE300, apologies.
- FURRYe38Jul 15, 2023Guru - Experienced User
- Shek5150Jul 15, 2023Aspirant
Very cool thanks for your help.
Out of curiosity, do you foresee a time when NG will come out with a fully copyable extender? . . not a big deal if this item will work . .. just curious.
Anyway, my irrigation system thanks you.
- Shek5150Jul 18, 2023Aspirant
FURRYe38,
Apologies for the bother; but before I seek out the EAX80; can you tell me if I could use then following as an extender?
I have a a satellite cube from a previous NightHawk Mesh Wifi 6 system; so, I have this satellite cube (MS80) . .. would this work as an extender . . . I'm guessing not; but thought I'd ask before spending the money on the MS80
thanks again for any help.
- FURRYe38Jul 19, 2023Guru - Experienced User
MS only work with in the MK system and have to be synced to the MR.
