rustyhawk43
Jan 16, 2022Aspirant
Image issues streaming while connected to CAT5
The tv downstairs in the family room started showing pixelated issues line Minecraft looking images. I removed the CAT5 cable from the TV and connected via wifi and it works perfectly, no image issu...
rustyhawk43
Hello!
It happended on the other tvs as well. I wonder what causes this issue on hard wired cable and wifi is good. I set the tv in the living room to wifi, then the one in the bedroom that is hard wired had the image issue.
Changed out the line and connected direct to router (bypassing switch). Still happended.
See attached. Not exactly the same image issue on the other tv but similar.
Rusty
Jan 17, 2022Guru - Experienced User
what modem/gateway is the router connected to?
What firmware is on the router?
