Paco15
Aug 29, 2023Initiate
Impossible to log in to a RAX80
Fairly wierd issue : I can't seem to access the management page of my RAX80 router. I'm automatically redirected to a 404 error page. This happens both on my desktop (with every browser) or my phone...
Aug 29, 2023Guru - Experienced User
How are you accessing this page? Routerlogin.net or 192.168.1.1?
What browser are you using? Try a different browser? MS-Edge or Firefox?
Be sure your clearing all browser caches before going to the routers web page.
- Paco15Aug 29, 2023Initiate
Using the IP adress throws me this error both on my phone and computer. Tried every browser I could think of (even reinstalled Opera haha), emptying cache and everything and no chance.
Routerlogin.net just throws me the webpage.
- FURRYe38Aug 29, 2023Guru - Experienced User
Has a factory reset and setup from scratch been performed? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-routerTry this disconnected from the ISP modem.
