Paco15
Aug 29, 2023Initiate
Impossible to log in to a RAX80
Fairly wierd issue : I can't seem to access the management page of my RAX80 router. I'm automatically redirected to a 404 error page. This happens both on my desktop (with every browser) or my phone...
Paco15
Using the IP adress throws me this error both on my phone and computer. Tried every browser I could think of (even reinstalled Opera haha), emptying cache and everything and no chance.
Routerlogin.net just throws me the webpage.
Aug 29, 2023Guru - Experienced User
Has a factory reset and setup from scratch been performed? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Try this disconnected from the ISP modem.
