monarch
Jun 24, 2020Follower
IN the Nighthawk AX80 firmware the reboot button is continually red even after a reboot. ??? Normal
Nighthawk AX 80 firmware reboot button continually red. I would think that a reboot is needed but reboot does not change that ? Is this normal ?
Jun 24, 2020Guru - Experienced User
Reboot button? Or power button/led?
If you go to netgear.com/support/ type in your model number. it'll bring you to the manual for your device where it explains what each led means
