monarch
Jun 24, 2020Follower
IN the Nighthawk AX80 firmware the reboot button is continually red even after a reboot. ??? Normal
Nighthawk AX 80 firmware reboot button continually red. I would think that a reboot is needed but reboot does not change that ? Is this normal ?
svandy29
Jun 26, 2020Aspirant
I experienced the same issue when trying to update to the latest firmware. I would run the update and then the router would never successfully reboot. It would get stuck with the amber power LED and the wifi LED lit.
What I had to do is a hard reset so the 30-30-30 to reset the router to factory. Then login and check the firmware. If the firmware needs updating download it manually from the netgear site and apply the latest firmware (May require another hard reset after). Once that is complete you can then re input all of your configuration (I did not have success loading from a backup it gave me the same issue on reboot).
Hope this helps someone.
