DraftPunk
Nov 01, 2020Follower
Incorrect info in attached devices
I've just purchased the RAX80 router and noticed that the information in the attached devices section is showing incorrect information and is terribly formatted. The devices shown have the correct na...
Christian_R
Nov 06, 2020NETGEAR Employee Retired
Hello DraftPunk,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
