jmorri36
May 16, 2019Follower
Increase Max Clients RAX80
I have about 200 small iot devices that I'd like to connect to the wifi network. They are not traffic heavy at all, but they all need to be connected at the same time. How can I increase the total ...
michaelkenward
May 17, 2019Guru - Experienced User
It seems to be a general wifi thing rather than device specific, so you might to look for generic answers.
It is a bit old now, but the technology hasn't changed that much:
How many clients can you connect wirelessly to a NETGEAR router? | Answer | NETGEAR Support
The Orbi seems to be different:
How many devices can my Orbi system support? | Answer | NETGEAR Support
kc6108
May 18, 2019Luminary
I completely disagree. This is the WiFi 6 (AX) Community. That KB doesn't apply to Netgear's WiFi 6 (AX) routers.
Netgear has been very clear on the subject:
OFDMA - 4X increased network capacity for more devices
All of these routers should handle 200 - 400 connected devices with ease.
- schumakuMay 19, 2019Guru - Experienced User
Cant' agree more. There are even more limitations and restrictions all over the Netgear routers - including the RAX models - "design". Not only the number of max clients per radio, also size of the DHCP table, the number of devices in the Access Control, ...
