esoxinator's avatar
esoxinator
Follower
Dec 31, 2022
install issue
AX3000 router     Why is there a red light on myn router .  second from them top
1 Reply
  • FURRYe38's avatar
    What router model do you have? AX3000 isn't a model #
    What does the user manual day about LED behavior?
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
