Wmlberryhill
Sep 09, 2021Tutor
Installed sax50s router in home. All devices connected but laptop. Laptop located all neighboring wi
Laptop will not recognize router. It locates all other networks in area. Any suggestions
- Sep 10, 2021Thank you very much for your help
Found wifi card on computer and opened tab. Went to driver file and there was a button to update driver. After updating everything is working fine.
Sep 09, 2021Guru - Experienced User
Not sure what SAX50's are. Maybe you mistyped a model number?
What laptop is it?
what wireless card is in the laptop?
What driver is installed for the wireless card?
Wmlberryhill
Sep 09, 2021Tutor
Model is RAX50S
Computer is older Sony VAIO
Not sure of wifi card or driver
- plemansSep 09, 2021Guru - Experienced User
Wmlberryhill wrote:
Model is RAX50S
Not sure of wifi card or driverThat wifi driver and card is key as some of the older wifi cards have issues seeing wireless AX.
Go to your device manager on the computer. It should list what your wireless card is. From there you can look up your driver.
Then go to the device manufacturer for the wirelss card (not sony) and download and install the latest driver.
- WmlberryhillSep 09, 2021TutorThanks. Will try when get back to computer
- WmlberryhillSep 10, 2021TutorThank you very much for your help
Found wifi card on computer and opened tab. Went to driver file and there was a button to update driver. After updating everything is working fine.- plemansSep 10, 2021Guru - Experienced User
Glad it was a simple fix!
