Wi-Ko
May 03, 2020Tutor
Instead of fixing 2 serous problems on my new RAX80 they stole my data and corrupted my PC!
Trying to get two problems fixed or a return of Router arranged I ended up with a serious security Issue and the local Police is involved. My two problems were: Access to readyshare drive drop...
- Jul 24, 2020
An Update
I was contacted by Management on this. In a recent interim feedback that induvitual suggested to have a 2nd level technician contact me regarding the two Rax80 problems mentioned in my initial post. That person phoned and I said I had switched back to my R7000 and would need to re-install the Rax80 first. So we agreed he would phone me back on the following Monday @10am. In the meantime I temporarily reinstalled the Rax80 using just my old PC. There was a new firmware available and I installed it.
Well no more file coruptions when tranferring files from the PC's to the readyshare. Also the readyshare was still available after more then 4 hours of non-use.
So both technical problems were fixed
However, strangly the 2nd level tech never phoned back. :mansad:
Here is info on a strange experience I run into for the forum's tech gurus.
Rather then deleting mostly old data, I reformatted the readyshare USB drive (3TB) using my Windows 10 Pro PC but neither the R7000 nor the Rax80 would now recognise that drive yet my Windows 10Pro PC and the Windows 7Ultimate PC did have no problems with it. Even run a 4-hr chkdks /r/f on it finding no problmes. I then formatted the drive via my Windows 7 PC and both routers now recognized the drive; the R7000 giving it a U: drive letter as before and the RAX 80 a T: drive letter. (was previously U: too)
So is there a difference in formatting between Win 10 and Win 7, which, while not having an inpact on either PC's but with both routers if using Win 10. Strange but that was my experience.
michaelkenward
May 04, 2020Guru - Experienced User
Wi-Ko wrote:
I received a call shortly after 3:30 on April 22nd, showing the correct GearHead tel #.
Not, unfortunately, an infallible guide. It is all too easy to spoof those caller ID numbers. Banks are particularly prone to that sort of scam.
There is a history sites and phone numbers purporting to be official support sites when they are no such thing.
I am not saying that this happened in your case, but it might be worth warning other people not to call numbers that they find with a web search.
