TSTIT
Jun 30, 2020Aspirant
Intel AX200/AX201 devices cause ALL 5ghz clients to stop communicating on R6900P
Hi, I've been struggling with this issue for several months and I've tried everything I can. I work for a large tech company and very network savvy and I've done everything I can to solve this o...
leglerreddin
Sep 18, 2020Aspirant
I have had the same issue with my router and it was the driver for the Intel AX200/201 that was causing the disconnect, update all of the adapters to the 21.120.2.1 driver version from 9/6/2020. This cleared up the exact same problem to me, hopefully thart helps.
- spacetimecontinOct 13, 2020Aspirant
I installed the 21.120.2.1 drivers from 9/6/20, but still having the same issue. Pretty remarkable. I've never seen something like this happen before. Netgear support is generally pretty good, hoping they resolve the issue soon.
- kf81Oct 15, 2020TutorDisabling mimo on the router cleared up the issue.
- capnron5177Oct 23, 2020Aspirant
Thanks for the suggestion to disable the MU-MIMO, that fixed the issue for me while able to keep my PC's bandwidth at 5G.
Even with the latest Intel AX200 driver installed just now (22.0.0.6, 9/17/2020), the issue still persists when the set to dual band or only at 5GHz a.
So, for my experience, it's either set my PC's Wifi to 2.4GHz or disable MU-MIMO.What would I miss without MIMO? I do have other PCs and devices, I have yet to experience lag even with the household streaming all at the same time.
- kf81Oct 24, 2020Tutorhttps://www.networkworld.com/article/3250268/what-is-mu-mimo-and-why-you-need-it-in-your-wireless-routers.html
This may provide some insight into your question.
