TSTIT
Jun 30, 2020Aspirant
Intel AX200/AX201 devices cause ALL 5ghz clients to stop communicating on R6900P
Hi, I've been struggling with this issue for several months and I've tried everything I can. I work for a large tech company and very network savvy and I've done everything I can to solve this o...
kf81
Oct 15, 2020Tutor
I'm having the exact same issue as described on my R7000P. Has anyone found a fix? I was able to get it to work properly when forcing the ax200 to use N like the original poster. I was also able to get it to work using AC by setting channel width to 20mhz on the 5ghz band, but then it only runs at 72mbps.
