chaeunwoo
Apr 20, 2023Follower
Interet/WiFi behaving very strange. RAX200
Hey guys. I'm seeing some strange behaviour on my WiFi at the moment and I'm trying to figure out what is happening. I have an RAX200 connected to Sky Fibre, and have an EX80 extender. 3 days ago,...
Apr 20, 2023Guru - Experienced User
Does the top Internet LED on the router change color when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Have you turned OFF the EAX extender and just connect to the RAX router to test?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
