noelft
Oct 15, 2022Aspirant
Internet Access Netgear AX5400
Having lots of issues trying to connect to my most used sites, won't let me connect on any of my PC's or Laptop anyone have an answer ?
noelft
Oct 16, 2022Aspirant
It's an AX6 with WIFI 6
michaelkenward
Oct 16, 2022Guru - Experienced User
That tells us even less. There are about a dozen AX6 models.
Netgear has made several "AX5400" routers.
RAX50,XR1000 and the SXK50.
As i said before, Look at the label on the device for the model number.
And the other questions?
- noelftOct 16, 2022Aspirant
RAX50-100NAS
Firmware Version v1.0.11.112
- michaelkenwardOct 16, 2022Guru - Experienced User
This is like getting blood put of a stone.
noelft wrote:
RAX50-100NAS
So, you have the latest firmware. But there is still some important unanswered question.
Connecting how?
On what?
What happens when you try?
Troubleshooting depends on having detailed descriptions of what you are doing, what goes wrong, and what you have tried to fix things.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?All we know is that you have "lots of issues trying to connect to my most used sites".
Whatever that means, it could be down to many things.
