tommev100
Aug 04, 2022Aspirant
Internet and Wifi Work on PCs, but not on Mobile Phones
Hello, I just set up my Nighthawk AX5400 Router. All of my PCs are connected with ethernet, laptops are connected with WiFi, and even my Roku streaming device can connect to it. All work perfect and ...
- Aug 05, 2022
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setupTry #2 first...
microchip8
Aug 04, 2022Master
You might disable the AX part as some (older) devices may have issues with it.
- tommev100Aug 04, 2022Aspirant
I enabled Smart Connect which appears to work. Perhaps there was a conflict with the 2.4 and 5G SSIDs.
My phone is a Google Pixel 6, and others are using iPhone 12s and 13s, so overall pretty new devices.
update: smart connect only worked on my phone. The others connect to the router, but don't get internet.
