tommev100
Aug 04, 2022Aspirant
Internet and Wifi Work on PCs, but not on Mobile Phones
Hello, I just set up my Nighthawk AX5400 Router. All of my PCs are connected with ethernet, laptops are connected with WiFi, and even my Roku streaming device can connect to it. All work perfect and ...
- Aug 05, 2022
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setupTry #2 first...
Aug 05, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
How is Advanced Wireless configured?
Set 20/40Mhz Coexistence to 40Mhz only. Enable or disable Beamforming and MIMO if seen. Save settings and reboot the router. Under Advanced Tab/Advanced Settings/Wireless Settings
tommev100
Aug 05, 2022Aspirant
The modem is Ubee UBC1322. It's capable of also providing wifi, which everyone can connect to and get internet with no problem. I don't want to use that as my wifi provider, though, as I feel more secure going through the Nighthawk. Should I turn off the wifi radio on the modem? They are sitting right next to each other.
- FURRYe38Aug 05, 2022Guru - Experienced User
Couple of options,
- tommev100Aug 05, 2022Aspirant
Thank you, this makes sense. I may need my ISP to disable the WiFi radio and configure the modem-only mode, as the available settings are very bare. At least I know it's not the router. I can just have the mobile devices connect to the modem for now and use the router for wired connections.
