DarkSorrow
Mar 13, 2020Initiate
Internet completely dropping
For the past 2 days my RAX120 Router is completely dropping ALL internet activity from all connected devices. When I reboot the router it works for maybe 15-30 minutes then drops all connections again...
terryharrison
Mar 16, 2020Aspirant
I'm having the same problems. Netgear sent me a new rax120 and it has the same problems. Tried 118 and 115 firmware.
Jimpilot5
Mar 16, 2020Star
For me a factory reset solved the issue. Pain in the butt but it worked.
- Jimpilot5Mar 17, 2020Star
Well. Spoke too soon. It lasted for about 48 hours, now it's back to dropping internet again. Guess it's time to open up a ticket with Netgear.
- welchyboyMar 17, 2020StarI am having the same issue. Downloaded the 118 firmware and within an hour wifi was dead. I can speed test from the router but all internet quits until I reboot.
- Jimpilot5Mar 19, 2020Star
I've found that if you have an iPad or whatever connected via VPN it doesn't loose internet when other items on the Wi-Fi do loose internet
