DarkSorrow
Mar 13, 2020Initiate
Internet completely dropping
For the past 2 days my RAX120 Router is completely dropping ALL internet activity from all connected devices. When I reboot the router it works for maybe 15-30 minutes then drops all connections again...
Boricua63
Mar 20, 2020Tutor
Thanks for your replies.
My router continues to disconnect from the ISP modem & dropping Wifi connections (both bands) and there is no rhyme or reason for this. Quite frustrating. Is there an internal test I can run on the router itself?
What I'm hearing is that even a total factory reset may not solve the problem. I did check the ISP vendor (modem & connection) and that is stable and no errors reported. This really started when I switched from Spectrum. Coincidence?
Am I going to have to buy a new router? Should I go with a Google device vs NetGear? I will do the research if I have to go down this path. The R7000 has worked well for the past few years. Thoughts?
I plan to reset it tomorrow morning when everyone is still sleeping then either restore the backup file or configure the devices one by one....
- TopologyMar 20, 2020Virtuoso
The (intriguing) observation by Jimpilot5 that “if you have an iPad or whatever connected via VPN it doesn't lose internet,” may suggest the presence of a DNS problem. In particular, note the similarity to the situation described in message #21 in RAX120 Router Random Disconnects. The solution appears to be a factory reset of the router, followed by manual entry of the settings (i.e., not importing a previously saved configuration file).
- Jimpilot5Mar 20, 2020Star
Topology wrote:The (intriguing) observation by Jimpilot5 that “if you have an iPad or whatever connected via VPN it doesn't lose internet,” may suggest the presence of a DNS problem. In particular, note the similarity to the situation described in message #21 in RAX120 Router Random Disconnects. The solution appears to be a factory reset of the router, followed by manual entry of the settings (i.e., not importing a previously saved configuration file).
I tried a factory reset a few days ago, it worked for a day or two then reverted. When I did I left everything in factory default when I did, didn't last long. I'm about two days into vpn holding solid connection, so somehow it has an effect. Wish Netgear would get on this.
Jimpilot5, you may be interested in messages #64 and #84 in RAX120 Router Random Disconnects which discuss the recent adoption of encrypted DNS-over-HTTPS by Firefox.
