DarkSorrow
Mar 13, 2020Initiate
Internet completely dropping
For the past 2 days my RAX120 Router is completely dropping ALL internet activity from all connected devices. When I reboot the router it works for maybe 15-30 minutes then drops all connections again...
DarkSorrow
Mar 15, 2020Initiate
I think I managed to fix mine. I pushed in the reset button then manually reset the router. Once I was connected I restored my settings from a backup. It's been 2 days with no issues so far.
JLinc
Mar 21, 2020Guide
A factory reset also worked for me, restored from backup. Almost 24 hours now without a drop. Will update if things change.
Currently running 118 firmware.
- Jimpilot5Mar 21, 2020Star
Currently running 118 firmware.My factory reset lasted about 48 hours. Only thing working is the VPN connect for me
- Boricua63Mar 21, 2020Tutor
This morning at 8am I reset my R7000 and I did not use a back up. It took me 3 hours to get all the devices properly connected and configured. Around 6pm I started getting connection drops. First my 5g connected devices then my 3 Ethernet connected devices dropped. I can see the LED for the Internet on the router totally go dark. When I plug in my desktop straight into the Internet connection it works fine.
What is happening here? Is the router going bad? It seems that is the problem. I'm out of warranty so unless I pay for support I'm stuck with this router or purchase a new one. This is very frustrating...
Boricua63 wrote:This morning at 8am I reset my R7000 and I did not use a back up. It took me 3 hours to get all the devices properly connected and configured. Around 6pm I started getting connection drops. First my 5g connected devices then my 3 Ethernet connected devices dropped. I can see the LED for the Internet on the router totally go dark. When I plug in my desktop straight into the Internet connection it works fine.
Sadly I'm afraid you are joining this group, all with the same problem.
