Ceebee1755
Jul 26, 2022Aspirant
Internet connection to caravan
I don't know much as will become evident and I think I may have brought the wrong thing..... I have a router AX2400 model RAX30 installed in a caravan. What do I need to get the internet? I assume ...
Jul 26, 2022Guru - Experienced User
Yes these routers need a Modem or ONT of some sort to connect to work fully as intended.
Depends on what ISP you choose. Thats up to you.
Ask the perspective ISP on what they support in regards to modems or ONT and what can be connected to them.
- Ceebee1755Jul 26, 2022Aspirant
Thanks.
