paperquill
Feb 15, 2020Aspirant
internet connection
Hello,Is there any way I can shut off my computer and still keep my internet connection via my router? Thank you. brownjpa@netzero.com
- Feb 16, 2020
paperquill wrote:
Hello,I tested it by unplugging the computer and nothing happened.
I had no internet connection to my tablet.These two sentences are confusing. If nothing happened, then all should be fine.
Or do you mean:
"I tested it by unplugging the computer and I had no internet connection to my tablet."
How does the tablet connect to the Internet?
Can it see the wifi from the router?
michaelkenward
Feb 16, 2020Guru - Experienced User
Yes.
The router will continue to broadcast wifi. You can also plug other things into its Ethernet ports.
Other then the wired connection, there is nothing else going on between the computer and the router. Test it by unplugging the computer and seeing what happens.
- paperquillFeb 16, 2020Aspirant
I had no internet connection to my tablet.What do you think I can do?
Thank you.- michaelkenwardFeb 16, 2020Guru - Experienced User
Or do you mean:
- paperquillFeb 23, 2020Aspirant
Hello,The router is connected to the modem.The ethernet connection
on the desktop computer is connected to the ethernet connection on the router.
If I disconnect the computer from the router,I lose the internet.If I turn on the computer
and leave the router shuy off the computer has no internet connection.
Sorry for the delay in responding.Thank you.
