paperquill's avatar
paperquill
internet connection
Hello,Is there any way I can shut off my computer and still keep my internet connection via my router? Thank you. brownjpa@netzero.com
  • michaelkenward's avatar
    michaelkenward
    Feb 16, 2020
    paperquill wrote:
    Hello,I tested it by unplugging the computer and nothing happened.
    I had no internet connection to my tablet.
    These two sentences are confusing. If nothing happened, then all should be fine.
    Or do you mean:
    "I tested it by unplugging the computer and I had no internet connection to my tablet."
    How does the tablet connect to the Internet?
    Can it see the wifi from the router?
