Sasartisan1955's avatar
Feb 13, 2023
INTERNET CONNECTION
My internet connection into my house is a coaxial cable from Xifnity and am trying out T-Mobile Gateway. I cut the cord with Cable and just need better coverage in the house.
thanks
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Sasartisan1955 wrote:
    .... am trying out T-Mobile Gateway.
    What's that? You have some sort of sort of modem/gateway that delivers the Internet to you? Make and model number?
    ....and just need better coverage in the house.
    And?
    You have flagged the RAX 30.
    You own one and want to set it up?
    You have a problem of some sort?
    Tell us more.
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Begin with the Quick Start/Installation Guide.
    There may also be some helpful videos on what to do.
    You may have done that already. I can't tell from your message.
    I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
