Canthony70
Dec 08, 2022Follower
Internet dropping every ten minutes, same time as lease renews.
I just bought the Netgear RAX42 router and every 10 minutes the signal drops for about 5 seconds and then comes right back on. The signal for the rest of the time is perfect, better than it has ever ...
Dec 09, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Are you wireless or wire connected to the router?
