Gene3222
Mar 31, 2023Follower
Internet interrupts.
Will the Netgear AX6 timestamp and record any internet failures or interrupts?
michaelkenward
Mar 31, 2023Guru - Experienced User
If you mean Internet interruptions, it logs those events here.
Look for something like this:
[admin login] from source 192.168.1.13, Wednesday, Jan 04,2023 19:58:58
[Time synchronized with NTP server] Wednesday, Jan 04,2023 19:58:04
[Internet connected] IP address: 217.43.151.249, Wednesday, Jan 04,2023 19:58:03
[admin login] from source 192.168.1.13, Wednesday, Jan 04,2023 19:58:03
[Internet disconnected] Wednesday, Jan 04,2023 19:57:51
[admin login] from source 192.168.1.13, Wednesday, Jan 04,2023 19:57:50
Thanks to my hopeless Internet service provider (BT in the UK), I am all too familiar with those entries.
Not sure about your unnamed AX6, but I suspect that most Netgear routers do the same thing, My router is a Mesh WiFi 6 system that has to remain anonymous to protect the innocent.
