TheReds
Jan 05, 2023Aspirant
Internet Led frequently turning off
My RAX50 having problems loosing internet randomly with Internet Led turning off. Startet two months ago. No problems before that, and no cable issues. Have to restart to fix. Most recent firmware. P...
TheReds
Thank you for reaching out.
Fw: 1.0.12.120.
Router is connected to a fiber modem (Genexis) that is also a ruter. Unfortunately not able to detach the modem to check for the model. The router functionallity in the modem was disabled (incl wifi) or in bridge mode years before the problems started. Connected to RAX with cat6 cable. Older netgear router (R7000P) worked fine. Hope this helps.
Fw: 1.0.12.120.
michaelkenward
Jan 05, 2023Guru - Experienced User
Fw: 1.0.12.120.
Well, you've raised the dreaded NAT issue, but you do seem to have it in hand. But disabled wifi is not the same as bridge mode.
Any chance that it reset itself and needs to be set up again?
Have you tried a reset on the RAX?
Do you have a power adapter you could try (from the R7000P?) to check that this isn't going bad?
