wimvpoel
Jan 23, 2021Aspirant
Internet Lost when activating VLAN/Bridge - By VLAN Tag Group
Hi, I have a WIFI6 Nightwak RAX120 Router. I want to create some VLANS on my private network and activated the VLAN/Brige option. I created an extra VLAN 30 under "By VLAN Tag Group" and pushed A...
wimvpoel
Jan 24, 2021Aspirant
Thanks!
So yes ... mmmmm... I believe I will need some thinking time now.
You clearly made some point now which will force me to rethink my strategy. E;G. the sense of wanting to separate the IoT SSID fro lthe other SSIDs (I have indeed an app on my android phone to control the airco units I have in the house ... )
But, on the other side, I also don't wat to spent further money in replacing e.g. the RAX120 to buy a router that has VLAN capability on the LAN side. (Ubiquiti Dream Machine PRO e.g.). I would believe (hope!) that the components I have in house, should enable me to make sure I've performant, secure LAN and WIFI network where IPTV doceders are also working when I plug them into my switch (plugging decoders directly in the Router of ISP Modem/Route is unfortunately NOT an option seen the loccation they are).
The screenshot you sent is excatly what I did on the RAX125. Only difference is that the VLAN for IPTV is 30 for the ISP I have. BUT... as I said... when I click APPLY on this screen, my RAX120 drop the INTERNET PPPoE connection with the ISP modem/router. Not sure if this is something to do with the ISP, or is this a Netgear RAX120 bug, or ....
In two weeks from now my ISP will come install Fibre at home, so I hope to speak then to a technical expert of the ISP... I'll check with them to see if they can advise....
Many thanks for you assistence....
To be continued :-)
Enjoy your weekend!
schumaku
Jan 24, 2021Guru - Experienced User
Could be indeed a router issue along with the feature and PPPoE.
Well possible there is no more PPPoE once you get fiber anyway.
