wsynx
Sep 24, 2025Aspirant
Internet not working
So I have the RAX50v2, the internet used to be fine however recently only the floor its on has internet (ground) and the kitchen (floor 1). However very bad internet in the living room (also floor 1)...
Sep 30, 2025Guru - Experienced User
Support does cost $ after a certain period. But if it turns out to be a hardware issue, you can get it refunded.
Before I"d try that though, I'd just try a scorched earth tactic and just factory reset it. Reset it by pushing and holding reset for 7-15 seconds while powered on. Then reinstall it. Don't use a backup in case its a setting issue.
I'd start there as usually support makes you try that step
