RowdyMarv
Aug 09, 2024Aspirant
Internet speed check works but no internet
NETGEAR - Nighthawk AX4200 I run the internet test speed on the app and everything comes back great. But no devices will connect. Once I noticed this I took a look at the router and found that the ...
- Aug 09, 2024
What model# router do you have? RAX##/###?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed ?
Turn off and unplug modem.
Turn on computers and rest of network.
RowdyMarv
I’m hesitant to say what the fix was lol but I had the cable plugged into the input 1 instead of the internet.
Aug 09, 2024Guru - Experienced User
That would probably be the cause.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
