Pizorro
Jul 20, 2021Tutor
Internet speed slows down when connecting to router
I have in my house a NETGEAR RAX80, there is fiber internet using a KingType PN-B04C modem, the modem was install by the cable company. We have 200 mg od download, when i connect the RAX80 router to...
Jul 20, 2021Guru - Experienced User
not much info on that modem. Does it have built in routing features?
- PizorroJul 20, 2021Tutor
Yes it does have router capabilities I believe, because it has wifi signal (weak) but it has.
- plemansJul 20, 2021Guru - Experienced User
Try putting the RAX in access point mode.
Or putting the RAX's IP address into the modem/gateways DMZ.
- PizorroJul 20, 2021TutorI can not access the modem, cable company will not give access. Can you please explain how to put the router in access point?
Thanks in advnace
