Hewvis
Feb 13, 2023Follower
internet way slow hardwired raxe300
internet plan is gig , when modem connected directly to comp get the speed when modem connected to the router then computer its down to 10mbps why ? , also nighthawk app cannot find the router
Feb 13, 2023Guru - Experienced User
1. what modem/gateway is the router connected to?
2. what firmware is on the router?
3. have you tried a different ethernet cable between router/computer?
4. have you logged into the router and checked its wan/lan connection page to see what speeds its connecting at?
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
