Dustin_V
Mar 19, 2019NETGEAR Employee Retired
Introducing the Nighthawk Tri-Band AX12 12-Stream Wi-Fi 6 Router
Leading the New Era of Wi-Fi 6, NETGEAR is proud to introduce the latest router to our Wi-Fi 6 lineup, the Nighthawk Tri-Band AX12 12-Stream router. Using the latest Wi-Fi 6 (802.11ax) standar...
Redtulips7
Mar 24, 2019Luminary
Dustin_V wrote:
Leading the New Era of Wi-Fi 6, NETGEAR is proud to introduce the latest router to our Wi-Fi 6 lineup, the Nighthawk Tri-Band AX12 12-Stream router. Using the latest Wi-Fi 6 (802.11ax) standard, the Tri-Band AX12 is designed to provide four times increased data capacity to handle more devices on your network. With blazing-fast combined Wi-Fi speeds up to 10.8Gbps, you’ll be able to power your smart home, stream ultra-smooth 4K UHD, game online, and more!
As the only Tri-Band Wi-Fi 6 router on the market, the Tri-Band AX12 is the fastest router for Gigabit internet. Tri-Band WiFi optimizes speeds across the three WiFi bands ensuring your WiFi stays fast and can efficiently handle multiple connected devices on your network. With two separate streams of data transfer over a 5GHz band, you’ll get smoother 4K/8K Ultra HD streaming and latency free online gaming.
Nighthawk Tri-Band AX12 features include:
- 12-Streams Tri-Band Wi-Fi - Ultra Wi-Fi 6 performance delivering multiple 4K streaming, low latency gaming & new blazing fast Internet speeds.
- Multi-Gigabit Internet - Maximize your Internet speeds up to 2.5Gbps with new versatile Ethernet wired connections.
- Gigabit WiFi to Mobile Devices - Enjoy streaming even more with ultra-fast WiFi speeds to compatible smartphones, laptops and more.
- Quad-Core 1.8GHz Processor - High-performance processor delivers fast & reliable connections to all devices & applications
To learn more about the Nighthawk Tri-Band AX12 router, please visit:
https://www.netgear.com/home/products/networking/wifi-routers/RAX200.aspx
Additional info about the Nighthawk Tri-Band AX12 router:
- What is a Tri-Band Wi-Fi 6 Router?
- What is the difference between the Nighthawk AX12 router and the Nighthawk Tri-Band AX12 router?
It has 2.2Ghz Processor not 1.8Ghz
- schumakuMar 24, 2019Guru - Experienced User
Where/how do you see that? Netgear does claim 2.2 GHz for the RAX120 - whereas Qualcomm says that the IPQ8074 operates at 2.0 GHz. But here on the RAX200 we face - similar to the RAX80 - a BCM4908, commonly clocked at 1.8 GHz.
- avtellaApr 01, 2019ProdigyYeah NG claims 2.2 GHz in manual I believe. That means it’s an IPQ8078 and not IPQ8074 (2.0 GHz).
- avtellaApr 01, 2019ProdigyFor the RAX120 I meant.
The RAX200 is definitely a BCM chipset unit with a 1.8 GHz cpu. Seems literally an RAX80 with an extra 5Ghz band plus a 2.5 Gbps Eth port.
- Redtulips7Apr 02, 2019Luminary
https://www.anandtech.com/show/13325/netgear-announces-nighthawk-rax80-rax120
https://www.snbforums.com/threads/netgear-stealthily-goes-public-with-its-draft-11ax-routers.49740/
