Dustin_V
Mar 19, 2019NETGEAR Employee Retired
Introducing the Nighthawk Tri-Band AX12 12-Stream Wi-Fi 6 Router
Leading the New Era of Wi-Fi 6, NETGEAR is proud to introduce the latest router to our Wi-Fi 6 lineup, the Nighthawk Tri-Band AX12 12-Stream router. Using the latest Wi-Fi 6 (802.11ax) standar...
Redtulips7
Apr 02, 2019Luminary
schumaku wrote:
Redtulips7 wrote:
It has 2.2Ghz Processor not 1.8Ghz
Where/how do you see that? Netgear does claim 2.2 GHz for the RAX120 - whereas Qualcomm says that the IPQ8074 operates at 2.0 GHz. But here on the RAX200 we face - similar to the RAX80 - a BCM4908, commonly clocked at 1.8 GHz.
https://www.anandtech.com/show/13325/netgear-announces-nighthawk-rax80-rax120
Redtulips7
https://www.snbforums.com/threads/netgear-stealthily-goes-public-with-its-draft-11ax-routers.49740/
- Redtulips7Apr 02, 2019Luminary
https://www.netgear.com/home/products/networking/wifi-routers/RAX120.aspx
- schumakuApr 02, 2019Guru - Experienced User
My question was related on the subject Tri-Band AX12 (RAX200).
