Dustin_V
Mar 19, 2019NETGEAR Employee Retired
Introducing the Nighthawk Tri-Band AX12 12-Stream Wi-Fi 6 Router
Leading the New Era of Wi-Fi 6, NETGEAR is proud to introduce the latest router to our Wi-Fi 6 lineup, the Nighthawk Tri-Band AX12 12-Stream router. Using the latest Wi-Fi 6 (802.11ax) standar...
Redtulips7
Apr 02, 2019Luminary
Redtulips7 wrote:
Redtulips7 wrote:
Redtulips7 wrote:
schumaku wrote:
Redtulips7 wrote:
It has 2.2Ghz Processor not 1.8Ghz
Where/how do you see that? Netgear does claim 2.2 GHz for the RAX120 - whereas Qualcomm says that the IPQ8074 operates at 2.0 GHz. But here on the RAX200 we face - similar to the RAX80 - a BCM4908, commonly clocked at 1.8 GHz.
https://www.anandtech.com/show/13325/netgear-announces-nighthawk-rax80-rax120
https://www.snbforums.com/threads/netgear-stealthily-goes-public-with-its-draft-11ax-routers.49740/
https://www.netgear.com/home/products/networking/wifi-routers/RAX120.aspx
schumaku
Apr 02, 2019Guru - Experienced User
My question was related on the subject Tri-Band AX12 (RAX200).
- Redtulips7Apr 02, 2019Luminary
No your question was wrong!!! So NG are lying about their Router speed, in their own websites and Spec.? or you own NG?
Ask me? Yes it's a cool looking Router but not so cool looking UI or features!!! Yes it works, if you ask me? No dropping Wi-Fi signal, wired speed little better than Nighthawk X10 but thats all...........
- schumakuApr 03, 2019Guru - Experienced User
I'm neither Netgear nor do I own Netgear. Hint: Read the line above stating "Subject"...
For those who don't trust the Netgear information ref. other models models vs. SoC clock speed (there were some hints in the media that NTGR is making use of a specialized version allowing a 2.2 GHz clock on the RAX120) - create dedicated threads please.
For information segregation, instead of accusing or insulting other community members, may I suggest to stop any off topic posting - that's anything unrelated to the subject "Nighthawk Tri-Band AX12 12-Stream Wi-Fi 6 Router" (aka. RAX200) please. - Redtulips7Apr 03, 2019Luminary
For information segregation, instead of accusing or insulting other community members, may I suggest to stop any off topic posting - that's anything unrelated to the subject "Nighthawk Tri-Band AX12 12-Stream Wi-Fi 6 Router" (aka. RAX200) please.Sound like NG Subject indicates AX12[RAX120]
- avtellaApr 03, 2019ProdigyThe RAX 120 uses an IPQ8078 (2.2 GHz Quad Core ARM Cortex A53 with 1.7 GHz Dual Network Cores)
The RAX 80 & RAX 200 use the same BCM4908 (1.8 GHz ARM Cortex A53 aka B53 with a 800 MHz Network Core) - kc6108Apr 03, 2019Luminary
Are we sure they aren't using a BCM49408 vs the BCM4908? I've seen both mentioned in multiple articles.
- schumakuApr 04, 2019Guru - Experienced User
The Nighthawk Tri-Band AX12 12-Stream Wi-Fi 6 Router (AX11000 class, RAX200 - this thread subject) and the Nighthawk AX12 12-Stream Wi-Fi 6 Router (AX6000 class, RAX120 - off-topic here) are two different products. AX12, AX8, and (announcement on April 9th) AX4 are used as a designators for the Wi-Fi 6 (AX) and the number of streams. I've left my comment ref. the misleading naming and designations earlier in this thread. - avtellaApr 04, 2019ProdigyNo you are correct it’s the 49408 on the RAX80/200, sound similar so I get confused lol. Pretty similar to the 4908 with addition of the 2.5 Gbps Eth capability.
- AltsaiApr 22, 2019NETGEAR Expert
No, it's BCM4908
It's typo on both website...
- avtellaApr 22, 2019ProdigyThey’re practically the same feature wise but there was also a Broadcom info site boasting about the 49408 in an upcoming Netgear router (AX80 released soon after. I can’t imagine the chipmaker would themselves be wrong...... I’ll try to find the link.
- avtellaApr 22, 2019ProdigyWell maybe it may just be the 4908, can’t find the site.
4908 and 49408 are the same. 49408 is major for enterprise segment not for comsummer.
- avtellaApr 23, 2019ProdigyYeah I figured that’s about the only difference but it’s hard to tell as sometimes the consumer units use those the “enterprise” chipsets like the Apple AirPort Extreme did.
- avtellaApr 23, 2019ProdigyLooking at FCC internal photos it’s 4908 indeed, the AX88U however seems to actually be the one with the 49408, though the FCC images on that one are a bit blurry you can make out just barely make out the 494 portion.
