Dustin_V
Mar 19, 2019NETGEAR Employee Retired
Introducing the Nighthawk Tri-Band AX12 12-Stream Wi-Fi 6 Router
Leading the New Era of Wi-Fi 6, NETGEAR is proud to introduce the latest router to our Wi-Fi 6 lineup, the Nighthawk Tri-Band AX12 12-Stream router. Using the latest Wi-Fi 6 (802.11ax) standar...
kc6108
Apr 02, 2019Luminary
Wikidevi may also have the CPU wrong for the RAX80/RAX200. It could be the BCM49408 which Broadcom classifies as a Cortex B53. A low power, quad-core, 64-bit, ARM v8 compliant CPU running @ 1.8 GHz. I've also read that the chip is supplemented by a 800 MHz network packet co-processor, but no where official.
avtella
Apr 03, 2019Prodigy
That’s is correct BCM calls it a “Cortex B53” but it’s using A53 cores essentially just like the faster clocked IPQ8078.
