broken_hawk
Apr 23, 2023Aspirant
"IP configuration Failure"
Hi, I bought a used nighthawk ax4 ax3000 model rax35 and I can't configure it no matter what. When trying on the app, no matter how many times I start from the beginning and reset everything includi...
Apr 24, 2023Guru - Experienced User
If its used, make sure to factory reset it before trying any setups on it.
Or old settings could be causing issues.
Push and hold reset for 7-15 seconds while powered on.
What modem/gateway is it getting connected to?
