CKelshaw
Oct 26, 2025Aspirant
iPad gets locked out of network
My daughter has an iPad 10 which is allowed onto my network. Every time she charges or updates the iPad, the network blocks the connection. When I log into the network I can see where the device show...
CKelshaw
I should also note I have an iPad 10 as well, and I have never had an issue! The only device which gets locked out of the network is hers.
- StephenBOct 26, 2025Guru - Experienced User
Do you have MAC layer access control enabled? Or perhaps parental controls?
- CKelshawNov 04, 2025Aspirant
No, I have no special parental controls or MAC layer access control enabled. I do use password and specific MAC addresses allowed on my network. Perhaps I misunderstand what your askking?
- FURRYe38Nov 04, 2025Guru - Experienced User
How are you determining this block? Where are you seeing this?
What NG router model is this?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/kb/en-orbi-knowledge-sharing/netgear-mobile-applications-and-androidapplewindows-devices-faq/2457046
