CKelshaw
Oct 26, 2025Aspirant
iPad gets locked out of network
My daughter has an iPad 10 which is allowed onto my network. Every time she charges or updates the iPad, the network blocks the connection. When I log into the network I can see where the device show...
Oct 26, 2025Guru - Experienced User
CKelshaw wrote:My daughter has an iPad 10 which is allowed onto my network. Every time she charges or updates the iPad, the network blocks the connection.
Do you have MAC layer access control enabled? Or perhaps parental controls?
CKelshaw
Nov 04, 2025Aspirant
No, I have no special parental controls or MAC layer access control enabled. I do use password and specific MAC addresses allowed on my network. Perhaps I misunderstand what your askking?
- FURRYe38Nov 04, 2025Guru - Experienced User
How are you determining this block? Where are you seeing this?
What NG router model is this?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/kb/en-orbi-knowledge-sharing/netgear-mobile-applications-and-androidapplewindows-devices-faq/2457046- CKelshawNov 05, 2025Aspirant
Any guidance on how to disable a MAC Address randomizer while at home? Also, I have an iPad very similar to hers, and yet I have NEVER had an issue with mine getting locked out of my network. What might the difference be between the two?
- FURRYe38Nov 05, 2025Guru - Experienced User
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
What iOS versions are on each pad?
Same or different model pads?
- StephenBNov 04, 2025Guru - Experienced User
That is MAC layer access control
- CrimpOnNov 04, 2025Guru - Experienced User
They key point is that Apple, Android, and several laptop brands have made the default setting of their WiFi to make up a new artificial MAC address when the device connects. Apple describes the feature in this article:
https://support.apple.com/en-us/102509
If the WiFi system has been configured to allow only certain MAC addresses to connect, then when the device creates a new MAC address, it will be locked out.
And, of course, in their infinite wisdom, every time the Apple device gets a software update, the setting is set back to "randomize". Why should Apple care that the user deliberately changed that setting? A royal pain in (anatomy)
- StephenBNov 05, 2025Guru - Experienced User
The article you cited says the default is "Fixed" for wifi connections with WPA2 or better security. My iPhone is set to "Fixed" and I've never seen that change. So CKelshaw could just make sure that the problem iPad either has the feature set to "Off" or "Fixed".
That said, "Rotate" is a problem for MAC address control, since the device will periodically change the MAC address.
Personally I don't see much value in MAC address access control, since anyone with the skills to hack into my wifi likely also has the skills to spoof a MAC address. So I keep that feature disabled.
