DavidmF
Apr 26, 2020Aspirant
iphone 11 and RAX 40
Recently installed a nighthawk RAX40. not 24 hours wifi began dropping and cutting internet off to all devices (wired and wireless). rebooted and one phone continued to drop off and on from the wif...
DavidmF
Apr 27, 2020Aspirant
4/27 update -
right after posting my issue, i tried one last thing.
I disabled the AX WiFi option. Went back to the iphone 11, entered the network password and it connected.
Hopefully that was the cullprit.
ronald_fr
Apr 27, 2020Luminary
Regards
Rob
Hello,
sure, if you remove the AX option, it works fine as for myself....
So the question is : why using a WiFi6 router ??!!
As I bought a WiFi6 router, I want to use WiFi6 functionnalities !
If not why do we have to pay +++
Regards
Ron
