Manazir
May 09, 2020Guide
iPhone 11 pro max drops wifi while locked/in sleep mode
Hi, I have started using Netgear Nighthawk AX8 router a week ago. Since then, I have noticed that my iPhone 11 Pro Max drops WiFi when it is locked or in sleep mode. Until I unlock the phone and do ...
Manazir
May 09, 2020Guide
Also, My PC is connected to the router via ethernet cable. Whenever I turn on the PC, It takes a minute or two recognizew the ethernet port and connect to internet.
Manazir wrote:Hi,
I have started using Netgear Nighthawk AX8 router a week ago. Since then, I have noticed that my iPhone 11 Pro Max drops WiFi when it is locked or in sleep mode. Until I unlock the phone and do some activity, the WiFi does not reconnect. It show connected to WiFi from the Router setup page but, message from WhatsApp, Messenger etc goes through. Also no other device connected to the Netgear Nighthawk AX8 was experiencing this issue.
Now, at first I thought it was a problem with the iPhone, so I tried reseting the phone & its wifi. I tweaked some setting of the phone too. But it did not work. Then I checked by connecting another router from different brand and found no such issue. Wifi was always connected, no drop when locked and all notifications came through. Did not get any issue while connected to those routers. I used "N" & "AC" router and found ok for both cases.
So, I thought may be problem lies with the Netgear Nighthawk AX8 router. I tried many ways to troubleshoot the issue but failed. Below are the methods I tried:
- Factory reset the router
- Updated Firmware to the latest version
- Turned off smart connect, AX feature, MU-MIMO, WMM. I tured them off individually and checked if it worked.
- Enabled IPv6 (even though my ISP does not support IPv6)
- Assigned static IP to the iPhone
- Changed WiFi channels.
- Removed Wifi from phone and reconnected.
Still no luck. The issue still persists. Can anyone please help me?
Christian_R
May 12, 2020NETGEAR Employee Retired
Hi Manazir,
Our engineering is aware and currently investigating similar reports. We do not have any further details or an ETA on a fix.
Thank you for understanding,
Christian
- ManazirMay 13, 2020Guide
Thanks for the reply.
Is there any solution/workaround currently? I am facing problem staying connected with my iPhone.
Is there any solution/workaround currently? I am facing problem staying connected with my iPhone. Christian_R
