todd1010
Feb 17, 2021Apprentice
iPhone 11 Pro Max not connecting to wifi; suddenly!
Not sure what is going on here but my wifi SSID’s are visible, I can connect on other devices and my phone has been connecting to it perfectly fine for the last year and a half. All of the sudden t...
todd1010
Also, on my phone I’ve reset network settings to see if it would fix itself and nothing changed along with restarting my phone.
- antinodeFeb 17, 2021Guru
> All of the sudden today it asks for the wifi password and after I
> enter it it says unable to connect. [...]Recent iOS update? Is Access Control enabled on the router?
https://support.apple.com/en-us/HT211227
> All other 32-33 devices in the house are connecting fine.
Not all on the same radio band?
> My router is a Netgear RAX120
Not RAX120v2? Look for "Model" on the product label. Firmware
version? Connected to what?- todd1010Feb 18, 2021ApprenticeiPhone has been on 14.4 the latest update since it came out without issues.
The Netgear router shows no update either.
I’m interested in this Access Control! I need to find what this is and how to figure out if this is keeping it from connecting.- antinodeFeb 18, 2021Guru
Doesn't really answer the question, does it?
> I'm interested in this Access Control! I need to find what this is
> [...]If you don't know what it is, then I'd guess that you're not using
it, but visit http://netgear.com/support , put in your model number, and
look for Documentation. Get the User Manual (at least). Read.While you're in that neighborhood, you might verify available
firmware.
