todd1010
Feb 17, 2021Apprentice
iPhone 11 Pro Max not connecting to wifi; suddenly!
Not sure what is going on here but my wifi SSID’s are visible, I can connect on other devices and my phone has been connecting to it perfectly fine for the last year and a half. All of the sudden t...
todd1010
Also, on my phone I’ve reset network settings to see if it would fix itself and nothing changed along with restarting my phone.
antinode
Feb 17, 2021Guru
> All of the sudden today it asks for the wifi password and after I
> enter it it says unable to connect. [...]
Recent iOS update? Is Access Control enabled on the router?
https://support.apple.com/en-us/HT211227
> All other 32-33 devices in the house are connecting fine.
Not all on the same radio band?
> My router is a Netgear RAX120
Not RAX120v2? Look for "Model" on the product label. Firmware
version? Connected to what?
- todd1010Feb 18, 2021ApprenticeiPhone has been on 14.4 the latest update since it came out without issues.
The Netgear router shows no update either.
I’m interested in this Access Control! I need to find what this is and how to figure out if this is keeping it from connecting.- antinodeFeb 18, 2021Guru
Doesn't really answer the question, does it?
> I'm interested in this Access Control! I need to find what this is
> [...]If you don't know what it is, then I'd guess that you're not using
it, but visit http://netgear.com/support , put in your model number, and
look for Documentation. Get the User Manual (at least). Read.While you're in that neighborhood, you might verify available
firmware.- todd1010Feb 18, 2021Apprentice
FIrmware version: V1.2.0.16
WOW, several of my devices are all of the sudden just like my iphone. My wifes school laptop and my iPhone aren't able to connect even though they have been for years. Now even after putting in the correct password (verified correct) it will not connect.
UGH!
