todd1010
Feb 17, 2021Apprentice
iPhone 11 Pro Max not connecting to wifi; suddenly!
Not sure what is going on here but my wifi SSID’s are visible, I can connect on other devices and my phone has been connecting to it perfectly fine for the last year and a half. All of the sudden t...
todd1010
Feb 18, 2021Apprentice
FIrmware version: V1.2.0.16
WOW, several of my devices are all of the sudden just like my iphone. My wifes school laptop and my iPhone aren't able to connect even though they have been for years. Now even after putting in the correct password (verified correct) it will not connect.
UGH!
antinode
Feb 18, 2021Guru
> [...] even after putting in the correct password (verified correct) it
> will not connect. [...]
"verified correct" _how_, exactly? Which radio band are these
devices using? Have you looked at the stuff in the User Manual under
"Specify basic WiFi settings"? Does the router think that its
wireless-network credentials are what you think that its
wireless-network credentials are? For both radio bands?
