Grafixmac
Apr 26, 2025Tutor
iPhone Connection to RAX70 - Connecting twice and more...
I have a Nighthawk 8-Stream Wifi 6 Router (XA700) - AX6600 (Model #RAX70), and I have multiple devices attached to my network (e.g.: TV's, Amazon fire sticks, Samsung phones, Chromebooks, etc.) as we...
Grafixmac
Apr 28, 2025Tutor
We have set the private wifi to OFF on his phone. Then I deleted the "second" attachment. However, it still comes back.
It shows the wifi connected status icon as "gray". If I delete it, it comes back. And then that one becomes the "new" phone that is the "real" phone (e.g.: the one I can turn wifi on and off for when he is using his phone).
Apr 28, 2025Guru - Experienced User
Review the MAC address seen the routers web page and compare that to what is seen on the phone under Private WiFi Address while that feature is disabled or set to Fixed. Those should be the same between the router and phone.
- GrafixmacApr 28, 2025Tutor
So what I see in the Netgear app for the one that is "green" matches his phone.
The one that is "gray" does not appear anywhere on his phone.
In my experience, this is what I believe is happening (but I do not want to test this anymore as I've been dealing with trying to fix this problem for months):
If I delete the one that is not in use (attached to my network, but not active on the wifi), what happens is that a new attachment appears, and this one becomes the main "active" one, and the one that was the active one is no longer active, yet still two appear, and now each have a new MAC address.
But this should not be happening at all with his private wifi set to OFF.
It could be several things, and while I do not think it is the router, the router does show two entries, and keeps doing so, so two things (apparently) are connecting (connected) to my network.
1) It could be due to the hack of his phone
2) It could be due to suspicious activity attached to his phone # (his Mint Mobile account got suspended today for suspicious activity)
3) It could be the way the phone works
4) It could be due to his Apple Watch
The long of the story is that his original Android phone number given to him by MM was also being used by another person. It was really strange, as his messages and the other guy's were getting crossed. But he bought a used iPhone and got a new phone #. We then installed a child monitoring program on his phone (like I had on my other kids' phones), and then the VPN started to go wonky (his iPhone needed the VPN based on the child security monitoring program), and apps started appearing in my alerts that were not on his phone. We removed this child monitoring program and I started to see all these other messages in that child monitoring app that were definitely not his, and we found hidden apps (tik tok, etc.) that he didn't install. So we factory reset that phone and then reattached it to the network. Two attached devices. So we bought a BRAND NEW iphone. He transferred his icloud to his new phone and here we are again. Two devices.
So while I cannot rule out this is how the phone works, that is the long story of it, and I don't know where else to post to find answers. It cannot be due to the original duplicate phone # since he now has a new number. It can't be due to the hack, since we factory reset his phone, unless somehow the hackers were able to actually hack thru the iOS and install malware on the firmware... that seems like NSA-level hacking.
And I think the MM suspension of his account is due to us transferring his phone number from his previous iPhone which had a physical SIM to his new phone with an eSIM and using Mint Mobiles app to do it.
But with so many variables, and not being an expert in any of this stuff, I am well beyond my comfort zone, and the issue I'm most worried about is that someone else is attached to my network and seeing everything we do. The ONLY solace I have is that with this router, I have the 2.4 GHz network and two 5G networks, so all of the kids' phones (his included) are on one of the two 5G networks, and the GUEST one to boot. But if there was someone spying on them, they could possibly see anything my other kids were doing. Creepy, but like I said, I am worried and stumped.
- GrafixmacApr 29, 2025Tutor
We called MM and have eliminated the possibility that someone else was using his new phone #. They put on the suspension only because he switched phones, and now his service is restored.
However, the original issue is still present.
