sodaman's avatar
sodaman
Follower
Jul 11, 2020
Iphone disconnects
I have my MR63 with two satellites evenly spaced in our house (2500sq ft).  When I go from one end of the house to the other I have noticed that it changes from one unit to another.  Most of the time it does this change fine, but sometimes it has trouble connecting to the the other satellite and sometime I actually have to reboot to get the change.  I have all reserved addresses.  What can I do to fix this??
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi sodaman,
    Ultimately, it is up to your iPhone to decide which unit to connect to based off of signal strength. You may try moving the satellites around to see if that would help.
    Christian
