peroberts
May 27, 2022Tutor
iPhone displays hidden network
My iPhone displays the WiFi connection as hidden, even though my Nighthawk RAXE500 router has SSID broadcast enabled. Any ideas?
- May 27, 2022
Does anything else say its hidden? Maybe its the iphone just displaying it wrong/different.
May 27, 2022Guru - Experienced User
- perobertsMay 27, 2022Tutor
Yes, it turns out that this is specific to this iPhone. It happened after a OS update. After reading your suggestion, restarting the phone resolved the issue, nothing related to the Nighthawk router settings. Thanks for your help.
- plemansMay 27, 2022Guru - Experienced User
Glad its working again!
