eb2114
Aug 21, 2020Tutor
iPhone won't move to satellite
Recently set up the Netgear Nighthawk MR60 using the set that you can buy at Costco. Setup is the router in the main living area and a satellite in an auxillary dwelling unit. There's definitely overlap in coverage between the satellite and the router, but all of the stationary devices in the AUD are on the satellite and have a strong signal.
The problem is that when I walk from the main living area into the AUD, my iPhone will only connect to the router's signal and won't migrate to the satellite signal, even when out of range of the router. Other devices seem to switch between the router and the satellite signal just fine. Is this just a known issue with the Nighthawk mesh system? Any tips on how to fix it?
Possibly relevant information: the iPhone is the only one with the Netgear app and was the device used to set up on the network.
Smells like an issue with your iPhone.
Have you consulted other iPhione users?
- eb2114Tutor
Yup, I just tried it with a different iPhone. When I get to the edge of the property, the devices are on the router's 2.4GHz band and don't move onto the satellite's 5GHz band.
