NorthernMike
Feb 21, 2023Aspirant
IPv4 & IPv6 VPN Tunnel on Nighthawk RAX45 AX6
I'm on the road with my Windows 10 laptop. I'm trying to open a VPN tunnel to my home where I have a NetGear RAX45 WiFi6 router. I'm running OPENVPN GUI v11.31.0.0.
I would like to force all internet traffic thru VPN tunnel to my router and then out to web.
The client config file below gets me connected to my router. But I leaking my location somehow as I am geo-blocked on the site I want to access.
whatismyip.com reports just the remote IPv4 address, but ipleaks.net reports the remote IPv4 address and a local IPv6 address. So I think I need to setup the tunnel and my router for IPv4 and IPv6. I think if there is a way to have the vpn capture IPv4 and IPv6 traffic I won't leak my local IPv6 address.
Is that possible? What router settings and client script do I need?
Below is the client .ovpn file.
client
dev tap
proto udp
dev-node NETGEAR-VPN
remote "*my router*"
resolv-retry infinite
redirect-gateway
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
comp-lzo
verb 5
- KitsapMaster
NorthernMike wrote:I'm on the road with my Windows 10 laptop. I'm trying to open a VPN tunnel to my home where I have a NetGear RAX45 WiFi6 router. I'm running OPENVPN GUI v11.31.0.0.
client
dev tap
proto udp
redirect-gateway
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
comp-lzo
verb 5I do not recognize the Open VPN GUI version you reference. The most recent Open VPN application for Windows is Version 2.6.0.
Do you have IPv6 enabled on your Router at home? Under Advanced -> Advanced Setup -> IPv6.
When you generated your Open VPN configuration package (four files), did you have the radio button selected to provide access to all sites on the internet & Home Network? See attached.
You might try using TCP for the TUN mode service? See attached.
Your configuration file appears to be old based on the cipher reference.
Are you using a Dynamic Domain Name Server (DDNS) service?
- NorthernMikeAspirant
That was just the GUI version, the application is v2.5.8
Yes. See the 2 attached screenshots.
Not sure. I've been changing router settings and don't remember when I changed that. I checked and made sure it was set to
Internet & Home Network, and redownloaded the files. The config file looked the same.
Will try that next.
I checked the router firmware and it is the latest available. I was getting warnings for this in the log and tried changing to
data-ciphers AES-128-CBC
data-ciphers-fallback BF-CBCand that broke it.
Yes.
- KitsapMaster
NorthernMike wrote:I do not recognize the Open VPN GUI version you reference. The most recent Open VPN application for Windows is Version 2.6.0.
Will try that next.
Yes.
No screenshot files attached. Depending on their content, a moderator may have removed them. I know pdf and jpg format files work the board. Others may not.
Attached is my redacted configuration file. I do not have any geoblocking issues I am trying to work around.
Note the cipher used. Open VPN changed their cipher requirements a couple of versions ago. Certainly before version 2.5.x.
Note: Open VPN just released client application version 2.6.0. The Netgear firmware has not caught up. I have several friends and family that just installed the 2.6.0 version and it works fine without any changes to the configuration files.
The only edit I made to the configuration file generated by the router was to change verb from 0 to 5. This provided additional information in the client log when a connection is made.
